Hey everyone, I just updated to VDJ 6.0.5 today. My questions is when I try to switch sonique effects on the fly while playing a song. It seems that VDJ freezes up. This is an awesome effect I use alot. Anyone else out there having issues? Any fixes?
geposted Sat 26 Dec 09 @ 12:40 pm
Same problem with sonique,dont know if your are using the first 84 x pack of effects that were posted for download (I am...) But those "algorythms" make Vdj cratch. And people know of this problem thats why he ( ) mentions a new package of 70 something that are supposed to be O.k. only i can't download them!! its a zip file and with winrar i get a an empty folder (?!) if you get them to download and work, let me know...
geposted Wed 30 Dec 09 @ 5:46 am
guys if you go to my blogs there is two tutorials there on soniques, one a vid the other text they may help you
geposted Wed 30 Dec 09 @ 10:16 am
My concern is the same as the others. It freezes things up. The big question is, if I just simply delete the Sonique or clipbank file in the program will that be all I need to do to get rid of it from the entire system or do I need to reinstall VD6.01? I just want it out so I know that if it crashes after that it may not have been Sonique? Help help, have gig in two weeks.
geposted Tue 04 May 10 @ 9:10 pm
This was an old thread!!.since then not only I've figured the winrar problem, but ive' got 10 more on top of the 72 pack offered here ,plus tons of more pluging imported from other applications. now my first question is..do you have the 72 pack or the 84 pack cause the 84 has some files that causes the freezups...in particular the "Nebulae" file..its bad!!second its..you still have the original folder copy in your download section? thats how you get around this situation see? allways keep the original files in new folders under downloads then copy & paste to VDJ. so at this point I wouldnt delete them all just make sure they are the Djcels certified pack then you can get 10 more from me. Oh! and you should of posted this thread at the "plugins discussions" but im not into nagging about that...Lol...you've would have seen my thread...
geposted Wed 05 May 10 @ 4:36 am
