I did a clean install of Windows 7 last month on my laptop, I have both VDJ and Serato installed. I cant seem to get my SL1 interface to detect in VDJ though it works in Serato without a problem.
Any ideas?
Any ideas?
geposted Sat 26 Dec 09 @ 3:52 pm
nevermind.. found it. Have to choose ASIO then select SL1
geposted Sat 26 Dec 09 @ 7:39 pm
did this work because anytime i select the sl1 driver it dosnt work
geposted Tue 06 Jul 10 @ 9:01 pm
no, it freaks out and quits working with my decks (HS5500 Denons) the new update really jacked up their native support in VDJ so I tried to use them with a timecode file through my SL1 box..
So i'm a little frustrated too :)
geposted Sun 11 Jul 10 @ 5:15 am
spool32...
just wondering if you can tell me what did you do for you to select the SL1 interface.....
i used to select that SL1 before but now when im trying to used on my new laptop windows 7
time code set up its not showing, it says asio driver not found.....
can you please help me out and if you dont mind show me the steps by step set up.... thanks
geposted Mon 29 Oct 12 @ 7:43 am
I sold my serato sl1 box a while ago, i think i found out it doesnt work with 64 bit pc's because of something with usb incompatability. I believe you need to use the sl3 box instead but i never got one
geposted Tue 30 Oct 12 @ 9:14 pm
