Finally got my Denon X-500 mixer in a case with my HC4500.
Got it to crossfade audio, but notice it only does that externally (the VDJ X-fader does not move) . When recording a mix I still have to crossfade in the program itself.
Can it control the internal crossfader of VDJ? Especially for vid's? If so how do I set that up?
Thanks gang.
Thanks gang.
geposted Sat 26 Dec 09 @ 8:08 pm
you have to make sure you connect the 3.5mm wire to the 500 and the 4500 then in the preset mode on the 4500 turn on x-control.
geposted Sun 27 Dec 09 @ 4:22 pm
Like I said it crossfades the audio externally with the mixer, but the internal crossfader on screen doesn't move.
geposted Sun 27 Dec 09 @ 6:18 pm
You could change the mapping for CROSSFADER to crossfader instead of video_crossfader - However, you will then not be able to headphone monitor from the mixer because VDJ is no-longer outputing sound for the channel that is faded out.
The best way to record with an external mixer is to run a cable from the REC OUT of the mixer to the line in of your computer's built-in sound card, then run 3rd party recording software such as Audacity to record the mix (If using the sound card of the HC4500, you can't record in VDJ from its line in because it does not have one.)
geposted Sun 27 Dec 09 @ 6:59 pm
How do you get the HC 4500 turn on to the pre set mode. I need to know how to turn on the xcontrol on the hc4500
geposted Tue 16 Feb 10 @ 1:04 pm
# Hold down the MEMO button on the the HC4500 to enter its built-in preset mode.
# Turn the parameter knob to choose X-CONT XFD
# Press the parameter knob to edit.
# Turn the parameter knob to change it to On.
# Press the parameter knob to save.
# Press MEMO to exit HC4500 preset mode.
geposted Tue 16 Feb 10 @ 2:05 pm
