Just got myself a Technic1200, and will be switching over to tc vinyl. I will be using my Hercules RMX as my mixer.
My question is, since funds are low.... and I can't afford another table for a bit,
Am I able to run Time Code Vinyl on my 1 table, and still use the Jog Wheel on my Hercules RMX for Deck B?
geposted Mon 28 Dec 09 @ 2:45 am
yes, you can use ONE turntable to control one deck of VDJ, and the other deck by RMX.
And you can even use ONE turntable, to control BOTH decks in VDJ, by easy swapping of what side the timecode should control ;)
geposted Mon 28 Dec 09 @ 5:14 am
For the longest, I used one turntable to control both sides. Just used the TAB button to switch the active deck.
geposted Mon 28 Dec 09 @ 9:18 am
What are the settings if I just want to play a regular Vinyl (Jay-Z) through my RMX?
INPUT : none
OUTPUT : headphone
SOUNDCARD : 4 out card
DRIVER: Hercules Dj Console RMX
Or do I change the Input to Time Code?
INPUT : none
OUTPUT : headphone
geposted Mon 28 Dec 09 @ 5:20 pm
Weird... it won't work.
Any Ideas??
Do I change the soundcard perhaps?
Any Ideas??
geposted Mon 28 Dec 09 @ 6:25 pm
Not certain, but I thnk you need to be in ASIO mode.
Roy
Roy
geposted Mon 28 Dec 09 @ 6:30 pm
I'm running Mac though.
Can't seem to get any sound to come out. I have the TT going into Input 1-2. Phono is selected.
It must be a Soundcard setting perhaps?
I have the traditional setting with my RMX... any ideas?
geposted Mon 28 Dec 09 @ 11:24 pm
