I just bought the Virtual DJ software a couple of days ago (recommended by my cousin). I set up my controller (Behringer BCD300) with the software. It works fine but after a couple of hours it stops by itself. I refresh the sound card (I hit apply at the settings) and it starts working again. Other thing that I found is that I'm having Clicks & Pops several times during the hold day and I use the same method I did when it freezes (hit apply at the settings) and It continues to work again for a while. I did the tweaks that I have seen in the Forum with my laptop (Windows XP Home Edition with SP2). I dedicated my Laptop only for Djing clean windows install with the Virtual, Controller & External Hard Drive. I used it the hold day today (from 9am to 8:30 pm) and I still had to do the process of refreshing my sound card a couple of times. What advise can you give me to help me set it to work properly and without gliches. Thanks for any help you can give me.
geposted Tue 29 Dec 09 @ 12:17 am
Hi mate
When you had to repeat the process with the BCD was this due to the pops and clicks or because the BCD had stopped responding?
Is it possible that your laptop power saving is still set to shut down the USB ports after a period of time?
Daz
Daz
geposted Tue 29 Dec 09 @ 4:35 am
i already did that and I did something else in the BIOS of the laptop. I haven"t check the last settings that I did. Thanks for the advise. I will double check to see.
geposted Tue 29 Dec 09 @ 10:03 am
