When cueing a song I can hear the song that I am not cuieng in my headphones and the control pot is set to the far left in the cue position not mix, the only difference I hear when switching back and fourth is the level attenuated, how do i kill it completly as to hear only the cue song. I have tried eveything as far as settings and redownloaded drivers.
I am running my laptop with VDJ 6.0.5 and latest RMX drivers.
geposted Tue 29 Dec 09 @ 4:27 am
Hi mate
Sounds like you need to have a look at the sound card setup under the config tab. I suspect you may have the RMX soundcard setup incorrectly.
Let us know what your settings are and we can tell you whats up.
Daz
Daz
geposted Tue 29 Dec 09 @ 4:30 am
It should look something like this:
- Input : None
- Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
-Soundcard: DJ Console Rmx
- Input : None
geposted Tue 29 Dec 09 @ 6:32 am
My setup is exactly like Dj phatso.
geposted Tue 29 Dec 09 @ 4:33 pm
Hi mate
If your setup matches what Phatso has posted then you would seem to have a more in depth problem. If you can post the full detail on your setup including how you have everything connected we may be able to help.
Daz
Daz
geposted Tue 29 Dec 09 @ 5:01 pm
hi i had the same problem until i disabled my pcs internal sound card now its fine
geposted Thu 31 Dec 09 @ 5:04 pm
