Topic: help with itunes
I recently got the dj console mk2 with virtual dj 3.4.1. on windows vista. All of my music is in my itunes library, but my virtual dj browser does not display my itunes. How do I fix this?
geposted Tue 29 Dec 09 @ 2:28 pm
go into browser in config settings mate and check itunes should do the trick
na man... when I go to config, there is no browser option...
should be 2nd last option mate.what version are you using mate.
when you open config go right hand side then click in browser/then check what you want to see on your vdj
I must have an old version or something? There is no browser option in my config settings
weird mate should be in all versions.what os are you using and how are you getting into config
It may be worth mentioning that if any of your music in iTunes says "Protected AAC" next to it, those tracks will not play in VDJ. If they don't contain "Protected" anywhere in that description, you should be all set. All the new music bought from iTunes says "Purchased" and those are ok. Hope this helps.
Is 3.4 an old version? I can drag and drop songs from itunes into vdj and play them, but I can not find itunes in the browser
Version 3.4 is almost 4 years old, the current version is 6.0.5.
never used that version mate maybe a teamer can help.
while on the itunes can you copy a playlist from itues to thumb drive if so how
yes.. but I think you can update to at least 5.2.1 ? (or at least thats the latest version my CUE LE reg allows)
Quote :
first you need to find the itunes folder using VDJ
on my computer it would be C:\Documents and Settings\[username]\My Documents\My Music\Itunes\
alright... how do I update?
the current version of VDJ Pro is 6.0.5
CUE LE (which is what came with most consoles) is at 5.2.1
Top of the webpage..
"DOWNLOAD" TAB
then "Software Updates"
https://virtualdj.com/download/updates.html
it should show your serial key, and the latest version you have access too..
or you should have the download in your download centre just click on it and save.
have your serial number at hand for install and happt spinning.
ps sorry for asking question in your thread
