A very annoying and dangerous option is the right click option over a song in the browser when in a Virtual folder list, the fist option is Remove, how many times in the heat of the memont I removed songs because it's so easy to make a mistake, you invest the time to organize your Virtual folders, it shouldn't be That easy to damage it.
This wouldn't be a big fix, this has already been done for the Regular and Filtered folders, why not the Virtual Folders?
Can you Please make Preview the fist option in Virtual Folders, that's what I use most often.
Ver. 6.5
Thank You
Joey...
Ver. 6.5
Thank You
Joey...
geposted Tue 29 Dec 09 @ 8:03 pm
