Hello!
I am using the Hercules dj console right now, and with the new feature in VDJ2.1(using only one turntable) i am wondering can i use the console, a turntable(with TCV) and an external mixer combined. Do i need a nother sound card. If i need a nother sound card , can i still use the console to control the other deck and other buttons.
I know i have to buy VDJ first.
Thanks Denis
Thanks Denis
geposted Tue 10 May 05 @ 6:28 pm
you would need the full version for more than one soundcard support
geposted Tue 10 May 05 @ 6:58 pm
yes, hercules can be used to control the programme.
Doesn't matter if the sound is passing thru it or not.
geposted Wed 11 May 05 @ 9:52 am
you can use the console, a turntable(with TCV) and an external mixer combined.
You would need another soundcard if you are going to use 2 turntables, such as the Maya44 soundcard (USB)
geposted Wed 11 May 05 @ 1:50 pm
Thanks for the anwsers!
If i would use only one turntable do i need a nother soundcard or can i use the console line in?
Denis
Denis
geposted Wed 11 May 05 @ 6:55 pm
you can use the console line in, or even the pc soundcard line in (with asio4all drivers... www.asio4all.com) it can work good
Problem with Hercules, is that there is no volume for line-in.
But it should work.
Another problem is that the asio drivers from Hercules have had some issues..
But still... it should work
And I know that somebody here is using hercules just like that
Maybe anyone can tell more?
But it should work.
geposted Wed 11 May 05 @ 6:59 pm
I am sure someone has already tryed this, please give me some info!
I am hot sure if i can use the pc soundard line in when the dj console is in use , cause it takes over the control of the onboard sound card(i think it disables it)?
Thanks for the info.
Denis
Denis
geposted Thu 12 May 05 @ 6:31 pm
the Hercules console should not disable the onboard pc soundcard....
Matter of fact, I use BOTH..... Onboard soundcard for samples
Regarding timecode use with Hercules line-in, I'm sure someone have tested that??
Anyone?
Anyone?
geposted Thu 12 May 05 @ 6:58 pm
Well i gues i will have to try it myself!
Would it be of any help if i buy a turntable that has a selectable output (PHONO or LINE), that means it has a amplifier Built in?
geposted Fri 13 May 05 @ 6:06 pm
dont think so...
VDJ have a software pre-amp.
geposted Fri 13 May 05 @ 6:08 pm
