hi guys i have just had to reinstall my system following a hdd failing..luckily i only lost software and some documents..
but now, since the new install every time i try to install my herc driver set, i get a blue screen crash that tells me the drivers were the problem.
now ive installed my herc drivers on several machines without ever having a problem. but now its happening every time.
anyone got any ideas as to what might be causing it???
geposted Wed 30 Dec 09 @ 10:46 am
Are you trying to install the latest driver version (4.HDJS.2009) ?
Which DJ Console are you trying to install exactly?
geposted Wed 30 Dec 09 @ 11:22 am
oh erm sorry for my lack of elaboration,
im trying to install the herc mp3 controll. the drivers are the out of the box drivers.
normally i have had a slight problem where i install the herc, vista says this device is not installed properly. then i get the option to re-install with recommended settings..which i do and it usually works fine.
only this time its not working its just crashing my system..
geposted Wed 30 Dec 09 @ 12:11 pm
I would recommend using the latest driver instead of the ones you have in the box ( which may be old ).
As well, after having reinstalled Vista, did you do all the operatiing system updates (at least Service Pack 2 (SP2)) would be required.
geposted Wed 30 Dec 09 @ 12:26 pm
ah thats probably my problem, no i havent updated it yet..i just needed to get back up and running due to me finally getting my soundcard. ill have to get back to youin a couple of days and let you know how things go because im thinking of upgrading to windows 7
geposted Fri 01 Jan 10 @ 8:51 am
