Hi guys, I am a beginner DJ. I recently bought the Hercules RMX Dj Console. I installed Virtual DJ LE that came with the console. Once installed it, I found that the crossfader has no use. The only way to swiitch decks is by using the Cue select button.
Doesn't Virtual DJ have the Cue ------ Mix fader at the top? Is the cross fader not supposed to work on Virtual DJ LE? Please Help.
Thanks
David
Thanks
David
geposted Thu 31 Dec 09 @ 12:16 am
Hi mate
It sounds like you have the configuration for the sound card part of the RMX incorrect.
Under the config tab. Go ro sound setup
Make shure you have the sound card set as follows: -
Input : None
Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
Soundcard: DJ Console Rmx
All should be well when this is done.
Daz
Input : None
Daz
geposted Thu 31 Dec 09 @ 4:17 am
Thanks for replying
But there is no options button on the Hercules RMX Virtual DJ LE.
Theres only a MORE and a REC button
On the MORE button, It just says Upgrade to VIrtual DJ Pro
It doesnt let me change the sound settings or anything
geposted Sat 02 Jan 10 @ 11:31 pm
Hi mate
If you can register the verion of LE that came with the RMX and post a ticket in help and support im shure the team can help you with this. I am not shure about the version you have but think all versions should have a config button somewhare. It may be that the skin you are using does not have this button.
Daz
Daz
geposted Sun 03 Jan 10 @ 4:43 am
i have the same prob no config button
geposted Fri 19 Mar 10 @ 12:31 am
@DoubleD12
You did connect speakers to Output 1-2 on the back of the Rmx, and your headphone to one of the headphone jacks, right ?
The LE version will only work with the Rmx soundcard, so you have to make the connection to it, not your computer's soundcard.
This way , the crossfader will manage the main output (1-2), and using the Cue Select buttons and the Mix knob at the top right to go between Cue and Mx, you'll manage monitoring.
geposted Fri 19 Mar 10 @ 5:02 am
