i am using the numark ns7 and i am shoping around for laptops and mac is way out of my rang that i would like to spend this is the one that i was looking at. would it work with the ns7 i am thinking about doing video mixing but still not sure
these are the specs
Gateway
Model: NV7802U
Processor 2.2GHz Intel Core 2 Duo T6600
Memory 4GB, 1,066MHz DDR3
Hard drive 500GB 5,400rpm
Chipset Mobile Intel GM45 Express
Graphics Intel Graphics Media Accelerator 4500MHD (integrated)
Operating System Windows 7 Home Premium (64-bit)
Screen size (diagonal) 17.3 inches
these are the specs
Gateway
Model: NV7802U
geposted Fri 01 Jan 10 @ 10:09 am
I woiuld look at a laptop with a dedicated video card if you are going to be doing video.
geposted Fri 01 Jan 10 @ 10:27 am
if i wasnt going to do video would this be a good laptop to get ?
geposted Fri 01 Jan 10 @ 10:47 am
For audio only.. This is fine
geposted Fri 01 Jan 10 @ 12:15 pm
is your ns7 working well with vdj?
geposted Fri 01 Jan 10 @ 2:48 pm
not with the laptop i have now it's 3 years old and i maxed it out to 2gigs and still not fast enough but with my friends macbook pro works great
geposted Fri 01 Jan 10 @ 6:08 pm
