Hello everyone,
I have a Hercules Dj Console mk2 and I wanted to know if I buy 2 Stanton t.80 turntables and use my dj console as a mixer , will it work properly or not ? Or should I buy an external mixer with the turntables and use my dj console mk2 as a sound card ?
Thank you !
Thank you !
geposted Fri 01 Jan 10 @ 11:34 am
I don't use turntable myself but I use the MK2. The MK2 will work as a mixer for your TT's but I'm certain most turntablists would use the MK2 as a soundcard and buy a good external mixer.
I think you would have to upgrade to VDJ Pro to use timecoded vinyl on an extended basis.
geposted Sat 02 Jan 10 @ 9:55 am
you are coreect TD Your going to need the pro vers. You can download the trial vers to test it out!! also you can use the MK2 as a sound card and hook a external mixer to use!!
geposted Sat 02 Jan 10 @ 11:35 am
