How do I switch "Audio Track" playing DVD Karaoke DVD? Thanks.
geposted Fri 01 Jan 10 @ 1:08 pm
Where can I find a manual Virtual DJ Pro?
Also, are there any kind of help features while using the product?
Thank you.
Thank you.
geposted Fri 01 Jan 10 @ 1:12 pm
Documents\VirtualDJ\VirtualDJ 6 - User Guide.pdf
geposted Fri 01 Jan 10 @ 3:40 pm
Could you please be more specific about the Path? Sorry, I am not certain on how to get there! Thank you for your reply to my post.
geposted Fri 01 Jan 10 @ 4:19 pm
From your START button ... Go to Programs , then VirtualDJ , you will see a User Manual listed there ...
The direct path is to your My Documents folder , in there the VirtualDJ folder , and then the User Manual
geposted Fri 01 Jan 10 @ 4:23 pm
Most of the VDJ file stuff is in a folder called C:\my documents\virtualDJ.
A file called virtualdjmanual is also in that folder that you can double click on.
Actualy (post being edited here) the file is in C:\documents and settings\"your name"\my documents\virtualDJ\.
"your name" stands for the name you assigned to the computer when you log in
I am evaluating VirtualDJ and after reading the manual, here is my impression regarding VirtualDJ Pro on VOB files:
1 - Supports Video and a Single Audio Stream.
2 - Does not offer Multiple Audio Stream with the ablity to switch between them.
3 - Question: - Do I need a plug-in to perform this function? If so, where/how can obtain the plug-in?
Please correct me if I am wrong and I appreciate all assistance.
Regards,
Regards,
geposted Sat 02 Jan 10 @ 8:18 am
