Working on building a library of Karaoke mp3+G and would like to know of recommended sites from those of you KJs out there.
Please direct.
Thank you.
Please direct.
Thank you.
geposted Fri 01 Jan 10 @ 10:32 pm
Hi mate
Check out selectatrak.com
Also sunflykaraoke.com
Daz
Daz
geposted Sat 02 Jan 10 @ 4:50 am
Like Daz said, Sunfly. I also recommend Sound Choice, DK Karaoke, Chartbuster, Music Maestro, Mr. Entertainer, Zoom, Top/Pop Hits Monthly, Legends Karaoke, Idol Makers, and more. Some of these are directly downloadable from the internet or can be shipped to you in CD+Gs for ripping to your hard drive. I have done numerous tutorial vids on my YouTube channel regarding karaoke.
You can find online companies that sell these brands of karaoke by doing a Google search using the brands listed above.
Good luck!
DJ RuDe
Keep Spinnin'!!
BTW: Join my music group "Karaoke Madness" if you would like... https://virtualdj.com/musicgroup/Karaoke_Madness__/
We need more KJs to join!
Good luck!
DJ RuDe
Keep Spinnin'!!
geposted Sat 02 Jan 10 @ 6:35 am
Thanks Daz and RudeDog.
I'll definitely check out the recommended sites. ;-)
geposted Sat 02 Jan 10 @ 7:12 am
can somebody tell me how to get virtual dj to echo like the real karaoke units is this posible? what do i have to do? thanks patrick.
geposted Fri 15 Jan 10 @ 10:08 am
if so can you tell what to purchase or what i need for it to echo and what i got to do software? hardware? thanks. kelly.
geposted Fri 15 Jan 10 @ 10:16 am
sorry i forgot to mention i have hucules rmx controller and virtual dj need that echo effect what do i do to get effect thanks patrick.
geposted Fri 15 Jan 10 @ 11:05 am
geposted Fri 15 Jan 10 @ 11:06 am
I think you figured out how to use the echo effect on the forum :)
geposted Fri 15 Jan 10 @ 2:44 pm
lol e-lectric
geposted Fri 15 Jan 10 @ 3:42 pm
I have about 6000 karaoke songs in the 2 file format of .mp3+g / .cdg. All my .mp3+g files are ID3 tagged meaning the right-click properties bring up the fields to assign the title, artist, date, genre and more. Will VirtualDJ use this the ID3 tag to display in the song list columns?
geposted Thu 11 Feb 10 @ 9:17 am
If you're talking about the browser, then, yes. VDJ will read the tags (as long as you have it set up to do so...Config->browser, check "read ID3 tags."
geposted Thu 11 Feb 10 @ 12:39 pm
I was also told that Virtual DJ can read the karaoke mp3+g file within a karaoke ZIP file, then read all the ID3 tags within the mp3+g file and display it. Is is correct?
geposted Thu 11 Feb 10 @ 1:06 pm
