I've been a 5.2 VDJ on my mac for awhile now... and have never really had an issues with it. It''s been really solid.
I've just recently picked up a 1200, and would like to switch over to TC Vinyl.
My question is, should I still use 5.2 and rock TC Vinyl or make the switch to 6.0.5?
Which version is better for TC Vinyl? Or are both results the same?
Thanks
Thanks
geposted Sat 02 Jan 10 @ 4:38 pm
all versions of 6 have worked lovely with TC vinyl. as good as it gets.
What's your interface? It will make a difference.
geposted Sat 02 Jan 10 @ 7:17 pm
can someone explain how does the virtual dj plugin echo out works
geposted Sat 02 Jan 10 @ 7:24 pm
I use my Hercules RMX.
Eventually I would like to get a mixer, but as of now, the RMX has been pretty good for me.
geposted Sat 02 Jan 10 @ 8:37 pm
i also use the rmx and tccd with external mixer if you want solid scratching you need external mixer but tc is solid with 6.5 but it all comes down to your computor and how it is setup but my advise rmx a+++++ and vdj 6.5 a+++++......
geposted Sat 02 Jan 10 @ 10:39 pm
so what is tha answer here??????? im confused..
is there actually a difference in the way the software works with TC's wheteher its v5 or v6????
if so what is the difference??
geposted Sun 03 Jan 10 @ 7:16 am
I think i remember some statements about tc drift in 6.0 up to 6.0.5 (?). I believe people say that 5.2 was the most stable witc TC.
geposted Sun 03 Jan 10 @ 8:47 am
6.5 is stable i had problems with all previous versions and 6.5 for me is most stasble
geposted Sun 03 Jan 10 @ 12:43 pm
im rocking the mixvibes tcv and i love it :)
geposted Sun 03 Jan 10 @ 1:52 pm
haha I have still gotten no clear response.
Perhaps we should tally votes.
5.2 or 6.0.5?
5.2 or 6.0.5?
geposted Sun 03 Jan 10 @ 10:30 pm
The best idea would be to try it for yourself... ;)
geposted Sun 03 Jan 10 @ 10:34 pm
i stick with 6.0.5 thats my final answer lol rmx user to rmx user
geposted Mon 04 Jan 10 @ 11:52 am
I want to switch over to 6.0.5, but if I don't like it... isn't it a bitch to go back to 5.2?
geposted Mon 04 Jan 10 @ 10:05 pm
no just message support and tell them what vertion you want and they will give it to you
geposted Mon 04 Jan 10 @ 11:04 pm
