I have just down loaded Numark V6.0.3 on my Home laptop and have been bench testing before I load it on the Laptops for the actual shows.
When The Wheel Mode is set to Browser and then I use the Jog Wheel to browse folders then switch to files, The DMC2 locks up.
Cue continues to play fine
This seems strange, but it only seems to freeze when using the Right or #2 player Jog wheel on the Controller
It does not seem to matter what file you try to load
I was running the DPC Latency Checker V.1.2.0 and did not see a red spike as it happened
I am running
Window XP Home edition V2002 Service pack 3
4-MCPU 2.20Ghz
2.19GHz, 2.00GB Ram
This is the same computer and set up I have been running
Only the update is different
I have been running V5.2.1 with DMC2 controller and DJIO external sound card.
I have had NO issue to speak off for I think close to 2 years now.
Thank you!
However, I like the idea you can map the DMC2 on this new version.
Any Ideas what could be causing the DMC2 to freeze?
Or is there a way to map it to V5.2.1?
Thank You
geposted Sat 02 Jan 10 @ 7:40 pm
