I use a Eee Pc 900 to do my DJing, I am going to buy a USB Audio Interface to do cueing. But I was wondering, if I buy two can I completely bypass my onboard audio so I can use the ASIO features of the cards for both my master and my cueing?
geposted Mon 04 Jan 10 @ 2:56 am
You would be better off buying only one soundcard that already as all the audio outputs you need, and has her own dedicated ASIO driver.
Here are a few examples:
http://www.djstore.com/group/soundcards.htm
geposted Mon 04 Jan 10 @ 7:42 am
Hi!
Dj Phatso is right. Buy one soundcard with the needed in- and outputs. Two cards will often result in conflicts regarding latency, drivers and so on.
Best regards
Marcel
Best regards
Marcel
geposted Tue 05 Jan 10 @ 12:54 am
