Hello everyone, I Nerio, I work as a DJ and use portable 2 for 2 different channels on the mixer and never let the silence in the evenings as well as the music also do karaoke, so I use a PC with programs of karaoke and a for music with VirtualDJ.
Now happens to reverse the roles of PCs cmq a problem with one of the 2, hence the need to install the various programs of music and karaoke on both.
After noting that I can use the Virtual for both, since I am allowed a maximum of 2, it installs and copy playlists created in the first laptop that is under C: \ Documents and Settings \ USERNAME \ My Documents \ VirtualDJ \ Playlists on same directory, among other things created by the same virtual moment of installation of the program, the second laptop.
Now as regards the files of the karaoke, I have both pc, while for the music that I am going to use with VirtualDJ, use an external hard drive that I move from one handset to another if necessary.
Just that the playlist did not load in the second laptop, or one where I copied the playlist created in the first.
Now I know what the reason, since the files come from the same directory, and for this I ask the Board to avoid having to create playlists in the second laptop, since I have many playlists and also quite long.
Add that to intuition makes me think that the laptop recognize the external hard drive with different letters, the first as the second G and F ... as if that was the problem, how can I make the second handset reads me the hard disk as the first, or G?
geposted Mon 04 Jan 10 @ 8:58 am
You can change the drive letter assignment of the external hard disk by going to Control Panel -> Administrative Tools -> Computer Management
Go to Storage -> Disk Management, right-click on the drive you wish to change and choose Change Drive Letter.
geposted Mon 04 Jan 10 @ 12:54 pm
If you don't want to change your drive letter. Open the playlist with notepad and use the search/replace tool to reassign the drive letter in your playlist. Ctrl H and in find type F: in replace with type G: then hit replace all and save your playlist.
geposted Mon 18 Jan 10 @ 8:51 am
