Hi, I currently use Virtual DJ 2.06 software. I have noticed a problem with the time coded vinyls. I can hear the time code signal underneath the actual music playing. My setup consists of a Shuttle PC 3.0ghz, lcd monitor, win xp pro, 2 sound cards(sound blaster audigy, intel 865glcl onboard sound soundmax). I plug the inputs and outputs for each which goes to the mixer, and setup the time code mode in options. Is this normal to hear this sort of feedback or what ever it is. it sounds like the time coded vinyl signal. Do I NEED a ASIO sound card? I am not sure but a friend has the same setup and he has no problems. My mixer is a pioneer djm600 and 2 x technics 1200 mk-2's. If you could get back to me would be appreciated... thank you.
geposted Wed 11 May 05 @ 2:57 pm
Cracked version = no support
geposted Wed 11 May 05 @ 3:13 pm
