hey i just bought this computer, i do not need to video mix but i want a smouth running system
http://electronics.hsn.com/gateway-15-6-4gb-ram-320gb-hdd-laptop-computer-with-webcam_m-10049219_xp.aspx?webp_id=5841017&web_id=5841017&sf=ec&dept=ec0027&cat=ec0033&ocm=ec|ec0027|ec0033&prev=hp!sf!dept!cat&ccm=ec|ec0027|ec0033
but this is what i bought
Key Specifications:
Processor: Intel Pentium Processor SU4100, 1.3GHz
Memory: 4096MB DDR3 1066MHz; upgradeable to 8GB
Hard Drive: 320GB SATA (5400RPM)
Optical Drive: 8X DVD-Super Multi Double-Layer Drive - Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (DL), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM. Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM double-layer (DL), 6X DVD-R DL, 6X DVD+R DL, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM.
Operating System: Windows 7 Home Premium
LCD Monitor: 15.6" HD WXGA Ultrabright LED-backlit display; 1366 x 768 resolution; 16:9 aspect ratio
Media Card Reader: Multi-in-1 Digital Media Card Reader - Secure Digital (SD) Card, MultiMediaCard (MMC), Reduced-Size Multimedia Card (RS-MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), xD-Picture Card (xD)
Other Differentiator: Integrated webcam, HDMI port Gateway PowerSave Button, Gateway MyBackup Button Touchpad Lock and Dedicated Numeric Keypad
what do you think
Key Specifications:
what do you think
geposted Wed 06 Jan 10 @ 10:00 pm
Why you bought it first and ask latter???
Well all is ok for audio mixing, but SU4100 is a energy saved processor. It is not a performance one, but for save energy and also, don't very good for VirtualDJ... maybe just changing the Energy options to ALWAYS ON and tunning this system, you could go with VirtualDJ playing audio very good.
Good Luck!
PS You don't need a Mac, you need to ask first before you buy to be sure what you buy is what you need or what would work for you.
Good Luck!
geposted Thu 07 Jan 10 @ 12:32 am
I wouldnt use this laptop for DJ use. I find 1.3 very low in speed. It won't be a smooth running system for DJ use. This laptop is more for the business traveler where the battery life can last a while because the processor doesnt consume alot of power. For DJ iing, i preffer 2.0 ghz duo core and higher with at least 2 gigs of ram.
geposted Thu 07 Jan 10 @ 12:33 am
