Topic: Virtual DJ 5.2
Does anyone know if I can still purchase v5.2... I had a trial saved for it and decided to use it when i found out how easy it was to map ion discover dj to it (works perfect) trial is running out and v6+ is not good at mapping this, can i still purchase v5.2.. ?
geposted Fri 08 Jan 10 @ 11:07 pm
If you purchase a license you can request any version be added to your download center.
I would like to request that v5.2 and 5.3 be added to my download center. Do I need to do a ticket for that ?
yes
Yes, please raise a support ticket .... the last V5 release was 5.2.1, there is no 5.3 as far as I am aware.
The mapping in V6 may seem complex, but it is far more flexible. Just takes a bit of time to learn.
how did you map you discover dj on 5.2?
But whin I follow that link, it does not work. It says I am not allowed, even though I have full purchased / registered version, and 6.0.9 does not recognize it. Any ideas?
Probably because your using a link from a thread thats six months old.
try
https://virtualdj.com/addons/controllers.html
and P.S. 6.0.9 doesnt recongnize anything because its non-existant ;-)
