I can no longer play video files they dont show up in file folders where there are tons of files there... is this being fixed?
geposted Sat 09 Jan 10 @ 5:58 pm
Which format of files?
geposted Sat 09 Jan 10 @ 6:29 pm
Also, make sure you have not Disabled video in the Video tab of the Config ... alternatively, make sure you select the second bullseye to the right of the search box and make sure you have 'Show videos' selected.
geposted Sat 09 Jan 10 @ 6:53 pm
every video format i can throw at it doesn't work anymore mpeg mpg avi mkv etc etc etc and like i said it worked before latest update and no i didn't have to change any settings before why would i now?
geposted Sat 09 Jan 10 @ 7:12 pm
Check "Files Infos" too and tell us the error written at the bottom of this window.
geposted Sun 10 Jan 10 @ 6:21 am
