okay i have my jog wheel set to control the effect sliders when effect buttons are held down
when i have Pass_TexZK_old effect turned on and hold down the key i have set for a variable a move the jog wheel the slider move just like is set...
how during NORMAL PLAY (just letting the track play) with the Pass_TexZK_old effect turned on, not holding my variable button, doesnt matter whether scratch mode is on or off, if i move the jog wheel on the deck the Pass_TexZK_old effect is enabled on
I get the awful noise and glitchy sound that last anywhere from 3-10 seconds and then it goes away........sometimes
any clue how to stop this?
geposted Sun 10 Jan 10 @ 2:34 am
okay with a little experimenting, I found that having the KeyLock on, the problem exists
KeyLock Off, and the problem goes away.....
Should this plugin be acting this way, or is it my performance settings?
geposted Sun 10 Jan 10 @ 5:18 pm
I have trouble when trying to use pitch reset with keylock on - horrible sound quality. I've since stopped using keylock altogether, and I limit my pitch range to +/-12%. Perhaps our issues are related in some way.
geposted Sun 10 Jan 10 @ 8:54 pm
Yeah I like KeyLock for a certain few things... like a particular scratch sound... but I am having to scratch with keylock OFF when I have the Pass_TexZK_old effect ON...
Which this is not so much of an issue as it is a nuisance...
I like using this effect along side a scratch sound, cause I can filter out some unwanted sound on the high end range or low end, depending on the sound I am trying to achieve...
And sometimes that KeyLock helps....but I am with you, I may just stop using KeyLock all together
geposted Mon 11 Jan 10 @ 5:55 pm
