i havent used my DJ Control for awhile now. when i last used it i could plug head phone into my sound card, and all was fine.
how i have just set up my control and it says i have to go "Pro" if i want to use my phones.
its let buying a car then some time later, you cant use the engine unless you pay again!
can anyone help? or did they just decide you cant use the controle!
geposted Mon 11 Jan 10 @ 7:52 am
You'll need to be a little more precise about what version of VDJ and the console driver your are using ( as well as which operation system you are running on) ?
geposted Mon 11 Jan 10 @ 8:04 am
You need just to use your VirtualDJ LE that cames with the console. Not activate the Trial version for 20 days. In that way you could use VirtualDJ with your console. Did you have a DJConsole MK2 or a DJControl MP3 Hercules console???
geposted Tue 12 Jan 10 @ 6:26 pm
