pitch in vdj does not change when i change it on my cdj. the speed of the song changes but the pitch slider does not move. this isn't good as it also affects it when you hit sync. if the slider on the cdj isn't at 0 then its off in the program. i NEVER had this problem with cue. why with vdj? what will fix this?
geposted Mon 11 Jan 10 @ 2:28 pm
I'm guessing you are using v 6.0.5 of VDJ. Try CUE 6.0.3 (If it never got updated to 6.0.5, my virtual vinyl did not). For some reason 6.0.5 on VDJ was also not responding to my CDJ's.
geposted Mon 11 Jan 10 @ 7:23 pm
yeah i was running cue 6.0.3 but was having crash problems. i was told to upgrade to vdj cause "why wouldn't you use that if its available" and this is one of the reason i didn't want to update. so i am guessing there is no work around or fix as of yet for this?
geposted Mon 11 Jan 10 @ 8:50 pm
i hear you. i only get crashes when I mess with the configurations. Other than that, it has not crashed on me. but 6.0.5 was not stable for me too. It still crashed.
geposted Tue 12 Jan 10 @ 12:12 am
weird. the thing that gets me is when you post a crash report you never get a REAL answer to what it is. its always a gernalized response. "external crash" search crash" then you get the good ol' the new update fixed it. blah blah blah. well yeah i don't get any more search crashes but now i can't move my pitch on my cdj. WTF
geposted Tue 12 Jan 10 @ 7:20 am
