i can't get it to work so far in 6.0.5 in windows7 64 bit
i downloaded it , it installed and i see it in the list of video efx , but it's not working so far
what have i neglected to do ?
geposted Mon 11 Jan 10 @ 8:46 pm
anybody home ?
geposted Tue 12 Jan 10 @ 6:49 pm
hey chuck how ya doin', start off with the silly ones i suppose... dx9 and c++ installed and you hit activate, right we got the easy ones out the way, now could this be connected with the other problems you guys are having with w7 & 64bit do you think.
geposted Tue 12 Jan 10 @ 7:18 pm
hi tayla , happy new year !
does the c++ come with the OS by default ?? also dx10 for w7 , i'm fairly sure .....
geposted Tue 12 Jan 10 @ 7:21 pm
i don't think so, hang on i'll get you a link... hope it's the right one, lol. http://www.microsoft.com/Express/VC/
and happy new year to you mate.
i got w7/64, i use dx9 & c++ on the desktop and works ok with it for me.
if it helps the dev team we beta tested as one of the results using that set up for our latest plugin.
geposted Tue 12 Jan 10 @ 7:22 pm
thanks Tayla, i don't care what everyone says about ya , yer awright .........
hey i'm confused and intriqued about yer firetext send info and links
send rum and loose women also
i know somebody posted this but i can't find it ....how to look up yer directx .....
btw i am hesitant to change or update the dirx bcuz video problems w/ my vid card and win 7 64bit ......
took some doing to get it (video) going 90% of what i want ........
xp was way easier .....
geposted Wed 13 Jan 10 @ 11:13 am
1/ i know somebody posted this but i can't find it, how to look up yer directx ..... just but a search in windows for directx, that will show you the .dll that is in place.
2/ send rum and loose women also... sorry i haven't got the necessary accreditation for that service
3/ hey i'm confused and intriqued about yer firetext send info and links... will pm you, but in the meantime take a look here, https://virtualdj.com/forums/116228/Virtual_DJ_Plugins/FireText_plugin_released_(Information_Inside).html the plugin is free to any legal VDJ user only the "SMSDJ" add on is chargeable if you want it.
geposted Wed 13 Jan 10 @ 1:27 pm
