My RMX works fine except the right deck does scratch in dj mode and dj mode in scratch. The left deck and all other controlls work fine. I have the latest firmware and drivers and have tested 3 different mixers. They are all doing the same thing. Anybody else witness this problem?
geposted Tue 12 Jan 10 @ 10:08 am
Under config->mappers, select the RMX from the dropdown (probably says keyboard when you open it), then change the SCRATCH action to the following: deck 1 vinyl_mode & deck 2 vinyl_mode. This will force both decks to scratch or not when you push the scratch button on the RMX. The default setup of the RMX mapper allows the scratch button to operate both decks independently, based on which one is "active" (PFL light on) at the time the button is pushed.
geposted Sun 17 Jan 10 @ 8:18 pm
