i am using a macbook os 10.5.8 and VDJ 6.0.5. and using my mini dvi out with a dynex video adapter .
how do i configure it so only the video appears on the screen or club and not showing the whole desktop screen on the tv?
geposted Tue 12 Jan 10 @ 3:06 pm
When you plug in your mini dvi adapter the machine should auto detect and dump you into display properties.
From there on the right side there is a "detect" button and then you will position your windows and desired resolutions.
Then in vdj just click conifg/video, click the drop box and select the video card, select activate and you should be good to go.
geposted Tue 12 Jan 10 @ 3:59 pm
took me a second but your instructions did the trick!
thanks so much
thanks so much
geposted Wed 13 Jan 10 @ 6:10 pm
