Topic: vdj cratching while controlling sonique
O.k.... I see that i need to Post my own subject 'cause no one is listening on the "Video Freezes" forum...Anybody have any Idea whats going on? My system "gets stuck" and cratches while using videos,sonique,logo..and messing me up!!! Anyone with the same problem?
geposted Tue 12 Jan 10 @ 10:37 pm
Would you say it's the same issue as on the video freeze thread? When you say crash, do you mean VDJ stops working, closes, what? What version of VDJ? If you gave more info, we would not have to ask all these questions.
Oh yeah...it stops working, ad in one case i couldnt close it! had to go to task and "terminate" I had 6.0.1 and now 6.0.5 ,still a problem! running it on a new Dell inspirion 1525 (duo Pentium 2.0ghz ,2gigs of ram ) and my controller is the Hercules RMX...any ideas?
Nevermind!! its SBDJ to the RESCUE!!..scott mentioned about the sonique pack (vs2 the ones posted now ) which i knew about but my damm winrar would'nt extract the files. scott let me know that he had just checked them as O.k. so i tried again and got them! then tested them,...all its Cool in DA FRONT!!! that Boy is a Genius I tell u !!! but still need to make a LONG RUN TEST!! will post RESULTS...G..allright?
you want to go through them individually and clean out some of the more rubbish ones as well.
Darn!! I did the test while recording. No Cratching!!..but now theres some POPPING on the AUDIO ,and it seems too be that the plugings (Show Logo,Sonique in slideshow mode,texters at the same time) are stresing it a little But this is while monitoring. it did not show on the output recording.Also im wondering (Joey..) if running Memory improve master & the Game Booster in the background (as suggested) would add more stress as opposed to relieve it.. (hi Tayla!!..Hey just saw the old post when you guys where Beta-testin the FireText..but what is it? and why so Expensive?)...Tracker..
i asked in another post but could you be more specific when you say your getting problems from "texters" which plugins are you meaning.
We reduced the price by nearly half this special edition for legitimate VDJ users. You only need to purchase the "SMSDJ" if you want to use that function, the rest of the plugin functions including the picture in picture for camera/video inputs are totally free, so go grab yourself a great plugin.
https://virtualdj.com/forums/116228/Virtual_DJ_Plugins/FireText_plugin_released_(Information_Inside).html
tayla..I usually use "showlogo" and "Sonique" then add "Scrolltext",then an Effect like "Pandoras box" or "Video Rotate" or whatever..why?
check your sonique quite a few of them are hogs on the cpu and delete them out of your folder, all you need to do is run sonique without the slideshow activated and select each file by using the open box and delete any with a high cpu and the ones you don't like. when complete re activate soniques slideshow button.
don't know if it will help in anyway but you will get rid of some of the muck that is there.
Humm..thanks.I've wondered "how do they make this? theres the ones inside media players (windows,Avs,VLC..) that I like.anyway of coping those? and the ones with Logos...I would Rewrite if i nkew how..
