Im torn Between Numark Total Control and the BCD3000 Pros And COns Please? Help a Starter.
Running VDJ6 on Vista.
geposted Thu 14 Jan 10 @ 12:11 pm
I used the TotalControl for about 2 years and it worked great. I beat the heck out of it though and that's why I had to replace it. The BCD 3000 looks cool because it has a soundcard built in, whereas the TotalControl doesn't. The question you need to ask yourself is what kind of DJ-ing are you looking to get into. I know the TC had a "plastic-y" feel to it and imo the Behringer looks the same, although I've never used it so I could be wrong (and usually am hehe). Either way they both look like good "Starter" pieces of gear, either one will help you learn the ins and outs of VDJ, although the BCD 3000 would probably win over the TC because of the internal soundcard. Good Luck, and don't forget the version of VDJ that comes with the total control is a limited version, same with Traktor.
geposted Thu 14 Jan 10 @ 6:17 pm
definitely Total Control i been using it for about two years and it never let me down i mean it works flawless with VDJ. it's truth has a plastic feels,but damn the total control works 100% without a problem. and I'll keep using it until it does not work.
it used to come with a VDJ le (not anymore) now only comes with traktor.
geposted Thu 14 Jan 10 @ 9:35 pm
ahh.. so TC doesnt have a soundcard? how are you suppose to monitor?
geposted Fri 15 Jan 10 @ 2:17 am
you ha ve to buy the DJIO Sound card
geposted Fri 15 Jan 10 @ 8:59 am
Also, if your using a desktop, you can install a second soundcard for monitoring.
geposted Fri 15 Jan 10 @ 9:57 am
Definitely Total Control. Numark over Behringer anyday!
geposted Fri 15 Jan 10 @ 10:51 am
