does anyone knows if lyrics olugin exists for Virtual DJ?
geposted Thu 12 May 05 @ 8:59 pm
What do you mean with a lyrics plugin. It is possible in VDJ to play Mp3+cd. The CDG file is a standard for karaoke files. So you could play the music and have the karaoke images (mostly lyrics only) on screen.
If you mean something else please give some more information
Ewout
Ewout
geposted Fri 13 May 05 @ 5:27 pm
Hi All,
Probably what SW611 means is he needs a Virtual DJ Lyrics Plugin which will connect to the internet and download the lyrics that will be displayed on the screen when you load a track and shows lyrics of the active deck or show lyrics of both Deck A and B or Deck A,B,C and D.
I hope my explanation is clear
geposted Sat 16 Apr 11 @ 2:00 am
it's the karaoke plugin, but you need the correct files to see the lyrics.
geposted Sat 16 Apr 11 @ 10:47 am
Honestly, I've been playing with this and it worked. But there was some other VDJ and other windows version. I downloaded MP3 file with LRC (simplified lyrics file).Then converted MP3 file to AVI (divx) and LRC file to SRT. What I get is simply music video (black background) with subtitles. Playing in any software player results with lyrics on screen, even in VDJ... but that was then. Now it don't work, the reason is probably related to codecs issues, but it's too deep for me. I'll try to find another solution...
geposted Sat 16 Apr 11 @ 3:59 pm
Got it working... again, but see for yourself ;-)
http://i51.tinypic.com/2ls7kzo.jpg
geposted Sat 16 Apr 11 @ 4:44 pm
