I let Mixmeister's BPM analyse all my song last night, it took hours.
This morning when i came to look at VDJ, half the songs haven't got a BPM next to them. Now i'm using VDJ to find them out :(
Any ideas what's happened?
geposted Sun 17 Jan 10 @ 8:32 am
tayla wrote :
yep
geposted Sun 17 Jan 10 @ 9:06 am
just kidding.... go to your folder where you have music and right click and select scan for tags
geposted Sun 17 Jan 10 @ 9:08 am
Ok, i've done that
What's that supposed to do?
geposted Sun 17 Jan 10 @ 9:34 am
it should have picked up the bpm tags from mixmeister, always used to when i've used it in the past
if you have thousands it won't show all immediately, you will slowly see the bpm coloumn filling up with those tags
geposted Sun 17 Jan 10 @ 9:40 am
You also got to make sure that those files are not read only, because mixmeister will compute the bpm and show it in the mixmeister software, but if the files are read-only mixmeister can't write the bpm to your mp3's.
geposted Sun 17 Jan 10 @ 12:10 pm
I have been trying to use MixMeister as well. I haven't had it do my whole library yet because the tags don't show up in Virtual DJ.
I checked that my files are not read only.
When I hit info on the files in Virtual DJ it the tag is there for BPM, not populated, just underneath with the ^ to populate it. How can I tel Virtual DJ to use this tag all the time? Kinda odd.
geposted Thu 29 Jul 10 @ 6:24 pm
I haven't played with MixMeister in a while, but if I remember correctly, MixMeister stores all of its data in a separate file (per song) named something like:
Original_MP3_Name.mxm.
I don't think it updates the tags, at least not by default.
geposted Thu 29 Jul 10 @ 11:12 pm
Great,
So can you pass some comments back to the developers... Can you ask them to stop truncating the tags to 30 characters when analysing the BPM please!!!!!
In fact they shouldn't even be touching the other tags just adding/updating the BPM tag. I lost a lot of tag info when I tried it out on a number of files.
Cheers,
Roy
Cheers,
Roy
geposted Fri 30 Jul 10 @ 10:10 am
