Last night, I did find a song in a virtual folder that wasn't supposed to be there. The original database issues may need just a bit more tweaking, I suspect.
geposted Sun 17 Jan 10 @ 2:31 pm
Hi,
didi you use 6.0.5?
didi you use 6.0.5?
geposted Mon 18 Jan 10 @ 9:27 am
A Virtual Folder entry only happens from drag-n-dropping an entry to a referenced Virtual Folder ... I would not classify 1 file showing in a Virtual Folder a 'database problem'. It very well could be a reference that you have just never caught from the time you were setting your folders originally.
geposted Mon 18 Jan 10 @ 10:35 am
That's possible Cstoll, but what got me was it was just a file that I had recently played..then I think I had a crash/freeze thing go on and then I started up VDJ again..and when I returned to the "slow songs" folder that was when I noticed a "hot dance" song in the "slow songs" virtual folder...as it appeared at the top as soon as I went to the slow song folder.
Aftr installing VDJ6.05 I went through my virtual folders again and was quite sure (although not exactly 100%) that all songs in all folders were the right ones.
geposted Mon 18 Jan 10 @ 5:31 pm
I do understand that that is supposed to be the only way they get there (drag/drop)...but prior to 6.05 there were reports that others were appearing from some other cause...was wondering if this might still be happening with 6.05 and if the database just needs another closer look. :)
geposted Mon 18 Jan 10 @ 5:34 pm
I'm still getting, once in a while, a few random songs that appear in my virtual folders that are NOT supposed to be there. This was an issue in prior versions and MOST of those issues were resolved by VDJ6.05, however, this one seems to linger.
Is anyone else noticing this?
These songs that do float in a virtual folder appear to be fairly recently played songs, if that helps.
geposted Mon 22 Mar 10 @ 10:06 am
