Hi everybody
my RMX mapper is available @ https://virtualdj.com/addons/10400/mr_step_RMX_mapper.html
WARNING
this mapper uses "source" and "scratch" keys as shift keys: if you use external audio systems (cd players, turntables) linked to RMX or "scratch" mode is not advised to use this mapper
SHIFT MODES
in this mapper there are two different shift modes apart from default mode, on two different keys for keyboard and jogwheels: led status on relative key will inform you about its operative mode.
keys used as shift are "source" (deck 1 & 2) and "scratch" (middle)
to cycle through the 3 different modes you just have to press the relative key.
led off means default mode, led on means shift mode 1 and led blinking means shift mode 2
SHIFT SOURCE MODE
this mode is activated by pressing "source" key on both decks
SHIFT SOURCE MODE DEFAULT (source led off)
[1] loop in [4] loop out
[2] flip double [5] brake
[3] beatgrid [6] funny flanger
[<|] seek -4 [|>] seek +4
[cue] hotcue1 [||/>] play/pause
SHIFT SOURCE MODE 1 (source led on)
[1] loop 4 [4] loop 8
[2] beatbox [5] backspin
[3] overloop [6] DFV flanger
[<|] half loop [|>] double loop
[cue] hotcue2 [||/>] forward/reverse
SHIFT SOURCE MODE 2 (source led blinking)
[1] Crusher [4] Djos delay
[2] echo [5] Beat break
[3] filters [6] TexZK flanger
[cue] hotcue3 [||/>] forward/reverse
pressing play key in forward/reverse mode (mode 1 & 2) will invert the way track plays. you can't pause track but just invert its way between forward and reverse. in reverse loops won't be played.
in modes 1 & 2 [<|] and [|>] keys will respectively half or double the active loop beats
SHIFT SCRATCH MODES
this modes will affect only the way jogwheels work, it's activated pressing the "scratch" key
SHIFT SCRATCH MODE DEFAULT (scratch led off)
in this mode jogwheels will accelerate or slow down track playing (cue mode)
SHIFT SCRATCH MODE 1 (scratch led on)
in this mode jogwheels will control slider 1 on selected effect
SHIFT SCRATCH MODE 2 (scratch led blinking)
in this mode jogwheels will control slider 2 on selected effect
NOTES
every key / jogwheel acts on its relative deck (1 or 2) except shift keys
download missing effects from:
https://virtualdj.com/addons/effects.html
WARNING
SHIFT MODES
SHIFT SOURCE MODE
SHIFT SCRATCH MODES
NOTES
geposted Mon 18 Jan 10 @ 6:16 am
