i can search for 125 and 126 bpm but it wont let me search for 128bpm searching keys is okay what could be the problem i have most of my music is 128bpm i recently copied my electrohouse folder from my external to my internal on my hd with over 100,00 tracks
thanks
thanks
geposted Mon 18 Jan 10 @ 7:34 pm
VDJ can't find the music, because you changed the location. You need to add that drive to the search database.
geposted Mon 18 Jan 10 @ 7:58 pm
i did do that i added it to search data base it finds everything except when i do a search with 128 it doesnt show up
geposted Mon 18 Jan 10 @ 11:47 pm
If you search by the artist or title, does it find these tracks?
geposted Mon 18 Jan 10 @ 11:59 pm
it finds them yes but i would like to just search bpm's because i mainly mix with 128bpm it used to work with other version's in this one if i type 125 every song with 125 bpm comes up
geposted Tue 19 Jan 10 @ 12:04 am
Be sure you checked/select the BPM on search options and type 125-126 in the search box.
Hope that helps.
Hope that helps.
geposted Tue 19 Jan 10 @ 12:23 am
thank you that helped i did check the bpm in the search options the 127-128 helped thanks alot you guys are great customer service
Michael K
Michael K
geposted Tue 19 Jan 10 @ 12:34 am
