Forum: Old versions
Topic: VirtualDJ 6.0.1
Hey guys this is DJGodOfKingz Im new and 14 =]. Anyway im having some problems... Does anyone know how to sound effects on a mac OSX???!!!!! I having so much trouble the files are in DLL I try to put them in plugins/sound effects and I open virtual dj and I get nothing.. I am so confused...=[
geposted Tue 19 Jan 10 @ 8:57 pm
You should start by entering your license number into your profile informations, which would allow you to
- Update to the latest version of VDJ (v6.05)
- download effects and plugin (from this site) that will work with VDJ.
if you are trying to use VST effects, they will not work with VDJ since this format is not supported.
Make sure you download the Mac-version of the particular sound effect (if it is available). The DLL files are for the Windows-version, so they won't work on a Mac. All sound effects are not available for Mac.
why is "VST effects compatibility" listed in the features of VDJ6 on this website?
you have to learn to get wen you enter the sound effects make sure you noe waat your doing
I NEED A NEW VERSION OF VDJ BUT I DNT NOE HOW TO UP GRADE WIT OUT CREDIT CARD
Thanks for bumping a year old thread.
Purchasing requires a credit or debit card. If you have any other questions please start a new thread.
