I just spent most of the night trying to add songs to a playlist. I finished loading about 150+ songs and went to save it. I had a playlist with only one song on it, so I named it the same. It asked if I would like to overwrite and I said yes. I close out VDJ and open it back up. The only song it saved was the original one song. I then tried to delete the playlist and it will not delete. I have no idea what is going on. Am I just missing something stupid? Thanks for the help....
geposted Wed 20 Jan 10 @ 10:16 pm
You're not missing anything and you didn't do anything stupid. The overwrite feature doesn't work, nor does deleting a playlist. The only way to delete a playlist is go to the playlist folder within your VDJ folder and throw it in the trash. The problem still exists after like 10 VDJ software updates; I'm not sure why because it's been mentioned many times before and it seems like it would be an easy fix.
geposted Wed 20 Jan 10 @ 10:50 pm
I appreciate the help...
geposted Thu 21 Jan 10 @ 4:50 pm
