I don't know if this is a bug or a change in the way skins are supposed to be deisgned, but 2.1 breaks some skins.
When you activate a loop for 1/2 or 1/4 beat, VDJ doesnt recognize the button as activated anymore.
You can test it with the Mixstation skin.
Loops for 1 and more still work, but under 1, the button doest stay hilighted.
Raz.
Raz.
geposted Fri 13 May 05 @ 7:38 pm
Loop have changed in 2.1
So you might be right
geposted Fri 13 May 05 @ 7:47 pm
Change your shortcuts and the loops value in the .xml file of your skin this way:
- Loop 1/2: "50"
- Loop 1/4: "25"
- Loop 1/8: "125"
Other values (loop 1, loop 2, ...) have not changed.
- Loop 1/2: "50"
- Loop 1/4: "25"
- Loop 1/8: "125"
geposted Fri 13 May 05 @ 8:20 pm
Yes it is like Clax said.
I had to change my shortcuts and it worked, but when i tried the same in my "Timecoce Power" skin for some reason it not worked.
So maybe there is a bug related to skins.
Then i changed the loop action from button to textzone in order to make it work.
Anyone ?
Anyone ?
geposted Sat 14 May 05 @ 3:43 am
"selected" on skins seems not to to work anymore with loop 1/4,1/2,1/8
geposted Sat 14 May 05 @ 10:35 am
