everytime i go to play tune,using the load button,all i get is a really loud hissing noise.
I can't be having this in a set.can anyone help,asap?
geposted Fri 13 May 05 @ 9:31 pm
I've never had this happen with mine. Is this a new problem that just popped up or are the XP10's new for you?
Might be as simple as the unit not getting enough power from your USB port.
geposted Fri 13 May 05 @ 11:57 pm
