I cannot figure out for the life of me how to map decks individually!
In previous versions, I used to map the left EQs to a certain set of midi knobs and the right ones to a different set. This is very important. Now, I can't find anything for "EQ_low_deck 1" its just "EQ_Low" so one knob has to control both decks?! I need to be able to use the EQ's from both decks at the same time.
I'm sure I'm missing something here...
geposted Fri 22 Jan 10 @ 6:55 pm
Yes, you are :)
http://www.virtualdj.com/wiki/VDJscript.html
deck 1 eq_low
If you have a traditional 2-deck controller then so long as the controller is defined correctly it's not needed. Yyou would just use eq_low and VDJ would know which deck to EQ because the definition file would tell it.
deck 1 eq_low
geposted Fri 22 Jan 10 @ 8:33 pm
That was it, thank you!
geposted Tue 26 Jan 10 @ 1:51 pm
