Topic: external usb sound card
hi can anyone tell me what usb sound card adaptors are best to use & how do you get them to work so as i can run my virtual dj from my lap top (which is operating on windows vista) with 2 stereo outputs into 2 channels on my mixer thanks any advice would be greatly accepted
geposted Sun 24 Jan 10 @ 12:59 pm
When using an external mixer, I would recommend 3 stereo outputs if possible.
This way your sampler and prelisten is on the the third channel.. (its nice too have this extra control)
First a question are you going to use the mixer for cue? Are you using a controller ? Using as a second card?
At the moment I am using two different ones? Just started using the Hercules Deejay trim 4&6. I would recommend it as it also as the ability to connect via its 2 usb ports ext. hdd or a controller.
Here is a link or two so you can check it out in more detail.
https://virtualdj.com/products/hardware.html
http://www.hercules.com/us/news/bdd/news/42/titre/das-neue-audiointerface-deejay-trim-4-6-von-hercules-ma-geschneidert-fur-djs-
hope this helps
Oh yeah the old stand by is a SB 24bit live external soundcard
Perhaps someone will add more or give ya some better ideas or insights
