So I have many play lists, pretty normal
If I rearrange my music folders on my ext hard disk and then go into VDJ and to a play list
Any songs that I move that were in a play list are no longer valid and you get an error loading.
I can manually find the same song and readd to the play list then remove the one that does not work.
Is there any easier way to do this?
geposted Sun 24 Jan 10 @ 2:51 pm
Anyone??
I would really like to figure this out, its a major pain in the a$$ if you move your music around on your hard disk
geposted Mon 25 Jan 10 @ 11:42 am
I haven't found a way around this yet...When I rearranged tracks that were in playlists, I rebuilt the playlists (you're right, pain in the...).
geposted Mon 25 Jan 10 @ 2:45 pm
Oh well at least I am not alone....
If anyone figures it out let us all know
I will do the same
Thanks
I will do the same
Thanks
geposted Mon 25 Jan 10 @ 3:56 pm
Hi, here's a tip you can use
Procedure for PlayList link edits
1. Decide on the PlayList before you do any edits.
2. Highlight that PlayList, right click choose rename.
3. Once full name is highlighted, right click to copy or (Ctlr "C")
4. Paste into notepad. (Ctrl "P")
5. Make sure you're Playlist is in AutoMix window on right.
6. Search for the yellow file replacement and add it into AutoMix window, delete the bad linked file.
7. Complete the edits One file at a time, till completed.
8. Click on + icon choose save at the bottom, paste original file name from notepad.
9. Click Yes to overwright.
That should repair all PlayList bad links.
Joey......
Joey......
geposted Mon 25 Jan 10 @ 4:06 pm
Thanks, I will give that a try
geposted Tue 26 Jan 10 @ 7:35 pm
your welcome..
Joey....
Joey....
geposted Wed 27 Jan 10 @ 4:50 pm
Try loading all the songs into the waitlist then save the new playlist by clicking on the + sign then save. It just worked for me.
geposted Sat 17 Apr 10 @ 10:03 am
