Hi!
I've reasently got two radius 1000 player and i want to use their midi functionality. I'm having problems doing that in Virtual Dj. Because the midi stops working after a short amount of time. Then I have to replug the players to the computer and restart ty software. I wonder if anyone knows what the problem might be that causes the problem and is there a solution?
I'm working on a laptop with a intel t5450 processor, 4gb ram and win 7. Virtual dj version 6.06.
Thank you for your answers in advance!
geposted Mon 25 Jan 10 @ 5:19 pm
You are using just the trial version. The functions in this version are limited. So i think this seems to be a limitation of the trial.
Please correct me if i am wrong.
Greets, Heiko
Greets, Heiko
geposted Tue 26 Jan 10 @ 5:37 am
Not to hijack the post abit but the same happens with my bcd2000 when both that and the NI audio 4 dj are plugged in together. Could it be that there isn't enough bandwidth and a powered usb hub should be purchased?
geposted Tue 26 Jan 10 @ 8:57 pm
hi have you had any help with solving this problem? i have just purchased radius 1000 and the midi works then freezes i have a similar 4gb ram laptop. must be a conflict some where iam running ver 6 software .any help would be appreciated.
geposted Sun 29 Aug 10 @ 4:15 pm
Do not use USB hubs for units with USB 2 and ant the same time units with USB 1.1. The port will slow down to the USB 1.1 unit and then there is really not enough bandwidth for the soundcard.
geposted Mon 30 Aug 10 @ 1:49 am
i have just purchased radius 1000 and the midi works then freezes i have a similar 4gb ram laptop. must be a conflict some where iam running ver 6 .1.2 vdj software .any help would be appreciated.i have threee usb ports and the only thing connected is the radius 1000 so no additional sound card connected and i am running a liscenced version of vdj .
I downloaded a midi exe file to load the mapping from american audio site.
i have previously ran denon hd2500 midi controller and my herculees mk 11 was going to be my sound cards.
geposted Mon 30 Aug 10 @ 7:06 am
