Did searches for the forum on xp tweaks. Had to reformat my HD and don't remember the tweaks and I know they were on here.
geposted Tue 26 Jan 10 @ 7:25 am
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
The link below will help remove bloatware that runs unnecessarily on your computer.
http://www.pcworld.com/downloads/file/fid,67264-order,1-page,1/description.html
geposted Tue 26 Jan 10 @ 9:44 am
As well as the link Rick has posted, you could have a look at this one
http://www.blackviper.com/WinXP/servicecfg.htm
But please be careful, as the tweaks on the above link are a lot more advance that the Hercules tweaks
geposted Tue 26 Jan 10 @ 2:24 pm
ok, got it. thanks
also, wasnt there something here at vdj regarding the advance tab IE: backgound services, virtual ram, etc?
geposted Tue 26 Jan 10 @ 2:40 pm
geposted Wed 27 Jan 10 @ 7:00 am
must i do anything with virtual memory, will it make a difference?
geposted Wed 27 Jan 10 @ 8:58 pm
It depends on your spec. Whats in your PC ram wise?
geposted Thu 28 Jan 10 @ 8:01 am
believe it or not, before this laptop hd went bad and i had done tweaking I had no problems whatsover with vdj and videos with effects or anything. of course i didn't have the newest version of vdj either.
Anyway, i have a dell inspiron 8600. 2048 level 2 cache. Nvidia gforce fx5200 video card. video memory (according to bios) is 64mb. I'm running xp pro service pack 2 with the newest directx9. It has 1.50gb of ram, upgradeable to 2gb.
geposted Thu 28 Jan 10 @ 9:31 am
ok i got a copy of 6.03 and installed. worked fine except for a rmx issue. i installed 6.05 and have video problems. i reinstalled 6.03 and they went away. i am having some kind of sound issue with the rmx that i didn't have before.
UPDATE - STILL BAD WITH MPEG 4'S, after 4 videos. green lines and bottom of video jerking. Even with rmx unplugged.
geposted Thu 28 Jan 10 @ 8:56 pm
Does it need wmplayer to work better? I have an older version with service pack 2. I only had service pack 1 installed before. Maybe I should go back?
geposted Thu 28 Jan 10 @ 10:27 pm
geposted Tue 02 Mar 10 @ 3:30 pm
