OK before I run out and by a Mac I want to know if the soundcard that comes with Numarks Virtual Vinyl (http://www.numark.com/virtualvinyl) will work with a Macbook?? I thought I read some where in the forums that it didn't.........I have done a search but nothing comes up.
Thank for your time and your help.
geposted Tue 26 Jan 10 @ 7:40 am
Yes, it runs on a Mac.
geposted Tue 26 Jan 10 @ 8:08 am
Yes Dizzy you are right, the program it self will work but as for the soundcard that comes with the program it does not because there are no drivers for a Mac. I'm not sure if it will work with a bootcamped Mac either but doesnt that defeat the purpose of even buyin a Mac? If this has been changed let me know, thanks..
geposted Wed 10 Feb 10 @ 10:04 pm
The Virtual Vinyl sound card works with a Mac, I've been using it for 2 and half years.
geposted Thu 11 Feb 10 @ 2:34 am
It does work the software with the sound card. I have also been using it for a good 2 years now.
geposted Fri 12 Feb 10 @ 1:48 pm
Does it work the new mac snow leopard?? Does the driver install witht he new virtual viinyl 6 update? or is it simple as plug and play?
Cheers
Chris
geposted Mon 05 Apr 10 @ 6:27 am
Yes, it works with Snow Leopard, and it is plug and play, no need to download any drivers, just make sure the soundcard is plugged in before you open VDJ.
geposted Mon 05 Apr 10 @ 11:16 am
