hello,
i wish to play a complete album,
or create a playlist,
and leave the list playing.
and what happens is that it doesn't automatically play the next track.
do u know where the setting for this is.
hope i explained myself well.
and cheers for any feedback
geposted Tue 26 Jan 10 @ 6:31 pm
do a search in the manual for "Automix"
geposted Tue 26 Jan 10 @ 7:14 pm
andrew drag your songs you wish to play into the right handside panel, inside that panel click on the top most left icon and it will turn green i think, you have now activated autoplay, if you wish to skip a few tunes for whatever reason double click on the tune you want to jump to and you should be good to go...
geposted Tue 26 Jan 10 @ 8:09 pm
