i have all i need just can't get the videos to show by themselves with out stretching the little box to a bigger size i was able however to remove the logo..how do i config to get just the videos to out put
geposted Wed 27 Jan 10 @ 6:59 pm
If I'm understanding you correctly then you need to extend your desktop (in your display properties in windows) to the second display, then it will become available as a display in the VDJ video options.
geposted Wed 27 Jan 10 @ 7:07 pm
You need to change your Video option from 'Window' to your video card.
Look at the Video tab, and the first drop-down you find the entry 'Window', select the drop-down and choose your video card.
See page 44 in the User Guide.
geposted Wed 27 Jan 10 @ 7:08 pm
thanks to both of you ill try it now
geposted Wed 27 Jan 10 @ 7:14 pm
