can somebody help I tried to run the text2D but I keep getting the message Direct3D is not initialized. I don't anything about Direct3D can somebody help...
Dj Memo
Dj Memo
geposted Wed 27 Jan 10 @ 11:51 pm
Try activating the plugin before you enter the text.
geposted Thu 28 Jan 10 @ 4:45 am
As stated above all video effects need to be activated, and you find that little oblong box in the middle of the video effects browser just click on it and it will turn blue to indicate the effect you want to run has been activated.
so the sequence is from browser > click on effects > click video effects tab > highlight effect you want to use > click on activate box.
However you will need to have directx9 and c++ installed on your system for them to work.
geposted Thu 28 Jan 10 @ 5:52 am
I always thought that message was misleading and should have been "Text2D is not Activated" since the button says "Activate" on it not "Initialize"
geposted Thu 28 Jan 10 @ 5:53 am
It's the right message. Both issues may be in play here. You may need to install the latest Direct X driver. If you have the latest, then you need to activate the plug in first, as everyone has stated. For some reason, this is only true for some text plug-ins. You don't have to do this for the included text plug-in.
geposted Thu 28 Jan 10 @ 11:34 am
Thanks you Djs great help it does work....
Regards
Dj Memo
Regards
Dj Memo
geposted Thu 28 Jan 10 @ 11:46 pm
Like Tayla and the rest sayd..could be the sequence of turning it on (kind of strange?) but more than likely you need to download all the proper Direct X files and not just the recent one (2009?) but the previous ones (2006?). some of the Texters were "writen" back afew years ago.theres a link to download its in another Thread...I think in a Plugin Forum,look around the forums,its there. I had the same problem a while back..Good Luck!...
geposted Fri 29 Jan 10 @ 1:38 am
