Hi everybody!
I´ve installed today the latest VirtualDJ version, and as I open the program, it says "You have old Hercules Drivers. You will need to download and install the latest drivers to use your Hercules unit. Do you want to download it now?"
The DJ console, is completely removed, and I will not use it anymore...How can I uninstall completely the Hercules Driver? Or how can I make this message dissapear?
Thans a lot for your help!
geposted Thu 28 Jan 10 @ 12:49 pm
Do a system search for this file HDJAPI and delete it.
geposted Thu 28 Jan 10 @ 2:02 pm
I´ve already deleted the file, and VirtualDJ is still asking for Hercules software update...:(
geposted Thu 28 Jan 10 @ 3:02 pm
Has anyone had firmware issues with Hercules RMX? I have spent hours on the phone with tech support and noting
geposted Mon 22 Feb 10 @ 3:24 pm
geposted Mon 22 Feb 10 @ 3:25 pm
@Kengle816
Can you be a little more specific about the problem you are having ?
A description of your system and how got to that point would help.
geposted Tue 23 Feb 10 @ 7:20 am
I expect you did restart after uninstall, and restarted again after install latest drivers.
Windows 7 - RUN AS ADMIN everything you install or uninstall.
geposted Tue 23 Feb 10 @ 8:47 am
